Highlighted
Beginner
Nexus 93180YC-EX NX-OS 7.0(3)I6(1) Maximum OSPFv2 & EIGRP Instances
Does anyone know the maximum number of OSPFv2 and EIGRP instances that a Nexus 93180YC-EX running NX-OS 7.0(3)I6(1) will support? (Ideally citing a technical reference).
Cisco Nexus 9000 Series NX-OS Unicast Routing Configuration Guide, Release 7.x status:
"The configuration limits are documented in the Cisco Nexus 9000 Series NX-OS Verified Scalability Guide.";
But
Cisco Nexus 9000 Series NX-OS Verified Scalability Guide, Release 7.0(3)I6(1) only states:
"Guidelines and Limitations for OSPF Verified Scalability Limits
To achieve the highest scale, we recommend that you use a single OSPF instance instead of multiple instances."
Thanks!
2 REPLIES 2
Highlighted
Hall of Fame Expert
Are you referring to the number OSPF processes you can create in the global routing table or instance per VRF?
Highlighted
Does it make a difference? Trying to establish options for 1:1 routing instance-to-VRF mappings. If I can have, say, 10 EIGRP instances then I can probably simplify this design a bit...
Content for Community-Ad
