02-21-2019 06:26 AM
Got a 9504 with a N9K-X9732C-FX card and trying to enable MACSEC on a trunk port but I get the error: macsec is not supported on module 2 (Module 2 is the X9732C card).
I have checked the spec for the card on Cisco site and it says "Yes" that it supports MACSEC. But when I check configuration Guide about MACSEC it list only the X9736C-FX card. Also followed the Configuration Guide how to enable MACSEC so I think the config is correct, I get the error when I try to enable the macsec policy on the port.
Im using NX-OS 9.2.1, anyone have some ideas about this or does my card not support MACSEC?
02-21-2019 09:54 AM
Look at the below guide :
Guidelinesand Limitationsfor MACsec
02-21-2019 10:03 AM
Thanks for the reply.
Ive read this "MACsec is supported on the N9K-X9736C-FX and the N9K-X9732C-EXM line cards".
But if you check: https://www.cisco.com/c/en/us/products/collateral/switches/nexus-9000-series-switches/datasheet-c78-736677.html
It says X9732C-FX supports MACSec, so im wondering if it will be supported in an upcomming NX-OS release or is it just wrong information?
02-21-2019 11:21 AM
the documents linked in both posts apparently contradict each other...
The recommended release is nxos.7.0.3.I4.8b.bin, can you try and downgrade to that ?
02-21-2019 11:44 AM
I was using nxos.7.0.3.I4.7 but then upgraded to nxos.9.2.1.bin
02-21-2019 11:57 AM
Seems to be some document mistakes,
i followed the latest updated 11th Feb 2019
have you contact local SE for this issue ? raise an TAC to confirm
