Join Customer Connection to register!
433
Eric Marquez
Beginner
Nexus 9508 Dynamic Port Breakout
I'm having trouble performing a dynamic port breakout for a 9508, X9636PQ.  I want to breakout specific ports on my blade making using native 40G and others as 4x10 ports.  When I issue the command "interface breakout module 1 " I don't get the option to do a dynamic breakout.  How do I get this to work?
Article:
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/7-x/interfaces/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_Interfaces_Configuration_Guide_7x.pdf
(config)# interface breakout module 1 ?
  <CR>
Optics:
 type is QSFP-40G-CR4
 type is QSFP-40G-CSR4
Software
  BIOS: version 08.06
  NXOS: version 6.1(2)I3(4b)
  BIOS compile time:  09/10/2014
  NXOS image file is: bootflash:///n9000-dk9.6.1.2.I3.4b.bin
  NXOS compile time:  6/30/2015 22:00:00 [07/01/2015 05:16:11]
Hardware
  cisco Nexus9000 C9508 (8 Slot) Chassis ("Supervisor Module")
  NAME: "Slot 1",  DESCR: "36p 40G Ethernet Module"
  PID: N9K-X9636PQ         ,  VID: V01 ,
2 REPLIES 2
Reza Sharifi
Hall of Fame Expert
Not sure what you mean by dynamic,  but if you want to break out individual ports use this command:
interface breakout module 1 port 1 map 10g-4x
I figured out why I can't run that command.   I'm not on 7x.
