Nexus 9k no Netflow ?
I am trying to enable netflow on our new Nexus 9k switches. But can't find nothing. No feature which can be enabled.
Is it not supported ( yet ) ? Or am i doing something wrong ?
thnx
Software
  BIOS: version 07.17
  NXOS: version 6.1(2)I3(3)
  BIOS compile time:  09/10/2014
  NXOS image file is: bootflash:///n9000-dk9.6.1.2.I3.3.bin
  NXOS compile time:  12/22/2014 8:00:00 [12/22/2014 17:38:31]
Hardware
  cisco Nexus9000 C9396PX Chassis
  Intel(R) Core(TM) i3-3227U C with 16402544 kB of memory.
  Processor Board ID SAL18474KGL
  bootflash:   51496280 kB
  bash-shell             Enable/Disable bash-shell
  bfd                    Bfd
  bgp                    Enable/Disable Border Gateway Protocol (BGP)
  dhcp                   Enable/Disable DHCP Manager
  eigrp                  Enable/Disable Enhanced Interior Gateway Routing Protocol (EIGRP)
  evmed                  Enable/Disable Generic event detectors
  hsrp                   Enable/Disable Hot Standby Router Protocol (HSRP)
  interface-vlan         Enable/Disable interface vlan
  isis                   Enable/Disable IS-IS Unicast Routing Protocol (IS-IS)
  lacp                   Enable/Disable LACP
  ldap                   Enable/Disable ldap
  lldp                   Enable/Disable LLDP
  msdp                   Enable/Disable Multicast Source Discovery Protocol (MSDP)
  ntp                    Enable/Disable NTP
  nv                     Enable/Disable VxLAN
  nxapi                  Enable/Disable nxapi
  ospf                   Enable/Disable Open Shortest Path First Protocol (OSPF)
  ospfv3                 Enable/Disable Open Shortest Path First Version 3 Protocol (OSPFv3)
  password               Credential(s) for the user(s)/device(s)
  pbr                    Enable/Disable Policy Based Routing(PBR)
  pim                    Enable/Disable Protocol Independent Multicast (PIM)
  privilege              Enable/Disable IOS type privilege level support
  rip                    Enable/Disable Routing Information Protocol (RIP)
  scheduler              Enable/Disable scheduler
  scp-server             Enable/Disable SCP server
  sftp-server            Enable/Disable SFTP server
  ssh                    Enable/Disable ssh
  tacacs+                Enable/Disable tacacs+
  telnet                 Enable/Disable telnet
  tunnel                 Enable/Disable Tunnel Manager
  udld                   Enable/Disable UDLD
  vmtracker              Enable/Disable VM Tracker feature
  vn-segment-vlan-based  Enable/Disable VLAN based VN segment
  vpc                    Enable/Disable VPC (Virtual Port Channel)
  vrrp                   Enable/Disable Virtual Router Redundancy Protocol (VRRP)
  vtp                    Enable/Disable VTP
Reza Sharifi
Have a look at this document:
Netflow is not supported
http://www.netcraftsmen.com/what-features-does-the-nexus-9k-support/
Omitted: CFS, PTP, NetFlow, EEE, XMLIN (convert CLI to NETCONF format).
Reza Sharifi
