Nexus basic config ( not able to config interfaces)
abarakat81
HI Guys,
I have  a quick question regarding Nexus 7K configuration. I am really new to this. I am not able to configure interfaces on Nexus other than the VLANs. Is there anything i need to enable or check for this. that's the modules i have
Mod  Ports  Module-Type                         Model              Status
1    48     10/100/1000 Mbps Ethernet Module    N7K-M148GT-11      ok
5    0      Supervisor module-1X                N7K-SUP1           active *
10   32     10 Gbps Ethernet Module             N7K-M132XP-12      ok
I am getting this message when i try to configure interfaces.
N7K01(config)# int ethernet 1/1
Invalid range at '^' marker.
N7K01(config)#
please help me if you can.
Thanks a lot in advance.
5 Replies 5
ogamanya
Issue this command:
Show vdc
You might have a virtualised box (vdc) so interfaces are in different context
NO i have only the default VDC , what other than that i can check.
And if you do a show int status can are the interfaces listed?
AAA with command restrictions perhaps?
What do you get if you do
show int e1/1
i get nothing. Anyway  , apparently the cards was not installed correctly and it is working now.
Thanks a lot guys
