07-24-2013 11:14 AM - edited 03-07-2019 02:34 PM
We have a 2 new nexus 7000 boxes . It has a N7k-sup2 , n7k-m148gt-11l and a n7k-f248xp-25E cards . Originally we had a non E F2 card and it would not let us put all the ports in the same vdc . It was then indicated that if we went to a F2 E card it would be compatible with M1 card in the same vdc only it's not letting us allocate ports from both cards into the single vdc ,keep getting "error:1 or more interfaces are from a module of the type not suported by this vdc , which is what we saw before. Running 6.1.2 code . What now to get these to work within the same vdc. There shouldn't be these kinds of restrictions around these linecards . Am I missing something ??
07-24-2013 04:08 PM
Yeah, you need to talk to your Cisco SE.
The firmware to allow the F2e card to co-habitate between the M1/M2 and F1 card have NOT eventuate. So yes, the F2e card is behaving exactly like the legacy F2 card: F2/F2e card can only be in their own vDC and cannot co-habitate with M1/M2 and F1 card.
07-24-2013 04:44 PM
Before adding it to a VDC, can you try using this command first?
system module-type f2
07-25-2013 05:35 AM
Reza , this command doesn't seem to be an option for some reason . I see it in some documentation also but when you go into config mode it doesn't seem to be an option under the system commands . Could this be a licensing issue of some type, I know we can only create a single vdc for this setup . Any ideas?
07-25-2013 06:16 AM
Glen,
You are doing these commands from the admin VDC right?
Also, are you using sup-2 or sup-2e?
Reza
07-25-2013 04:11 PM
Yes doing it from the admin vdc , but that command is valid under the system command. This has a Sup-2 supervisor installed with version 6.1.2 .
