12-13-2019 09:02 AM
I have a quick question.
The MGMT0 interfaces are being used for peer-keepalive between the switches.
The MGMT0 interfaces are connected via a crossover cable (think), not via an intermediate switch.
Can you advise if the best practice is to connect mgmt0 interfaces with a direct crossover cable or they should be connected to a switch.
Edouard.
Solved! Go to Solution.
12-13-2019 09:22 AM - edited 12-13-2019 09:30 AM
They should be connected to a switch.
see figure-3 in this link for reference.
