10-14-2015 07:52 AM - edited 03-08-2019 02:13 AM
Is VDC's supported now on the Nexus 9K particularly on the N9K-C93120TX?
Solved! Go to Solution.
10-14-2015 09:02 AM
At the moment nexus 9K do not support multiple VDC concept like Nexus 7K.
check out the below link for more information
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/6-x/high_availability/guide/b_Cisco_Nexus_9000_Series_NX-OS_High_Availability_and_Redundancy_Guide/b_Cisco_Nexus_9000_Series_NX-OS_High_Availability_and_Redundancy_Guide_chapter_01.html
Hope it clarify your query.
-GI
Rate if it Helps..
10-14-2015 09:36 AM
Thanks that’s what I thought, didn’t know if something had changed in the last couple of months…..thanks
Hi Kevin,
Helpful if you can mark this thread as answered, so that others can also get benefitted.
GI
10-14-2015 09:02 AM
-GI
Rate if it Helps..
10-14-2015 09:24 AM
10-14-2015 09:36 AM
Hi Kevin,
GI
