Nexus_RAdius config
incognito
hi
Can someone check it? Is it right config for radius on nexus switch?
radius-server host 10.100.0.5 key 7 "******" authentication accounting
aaa group server radius RadServer
aaa authentication login default group RadServer local
aaa accounting default group RadServer
aaa authentication login error-enable
server 10.100.0.5
use-vrf vsan
balaji.bandi
here is example working config :
aaa group server radius RADIUS-BB
server x.x.x.x
server y.y.y.y
use-vrf management ( generally this go via Management, you can use any VRF which can reach to Radius servers)
radius-server host x.x.x.x key 7 "mykey" authentication accounting
radius-server host y.y.y.y key 7 "mykey2" authentication accounting <- if you have 2 Radius
radius-server directed-request
aaa authentication login console local <- in case if you lock out with Radius)
aaa authentication login default group RADIUS-BB Local
Do not write the config untill all tested and working
BB
1) Why did you use 2 server command? I have only one radius server (10.100.0.5). As i understand i can use only one server x.x.x.x command, right?
server x.x.x.x
server y.y.y.y
2) use-vrf management ( generally this go via Management, you can use any VRF which can reach to Radius servers).
In my case I have to use vrf vsan
3) For what do we use this command?
4) what does Local mean at the end of this command?
Can you check the config now?
server 10.100.0.5
use-vrf vsan
but radius sever is not working. I cant remotely connect to the nexus switch with radius(active directory) user credentials. Radius on windows server is configured correct. the problem is on the nexus side
