10-11-2019 04:31 AM
Hello
how to delete Nexus snmp-server default user admin
I have to delete/disable snmp in general. I deleted all snmp related commands except this given below command.
I need to configure new SNMP.
Nexus(config)#snmp-server user admin network-admin auth md5 xxxxxxx priv yyyyyyy localizedkey
when I try to delete this command:
1) Nexus(config)# NO snmp-server user admin network-admin auth md5 xxxxxxx priv yyyyyyy localizedkey
Cannot delete role for this user
2) Nexus-6001(config)# no snmp-server user admin
cannot delete user admin
Solved! Go to Solution.
10-11-2019 05:51 AM
On nexus environment admin is the super user, the user has all the rights, you can not remove those rights.
The admin user only used when required, you add other user account to be as admin and you can change rquired as per the requirment.
10-11-2019 05:51 AM
10-15-2019 01:29 AM
hello @balaji.bandi
Can I change the password for 'snmp-server user admin'? If i can change password for admin user then there is no need to create another snmp-server user. Is it possible?
10-15-2019 04:54 AM
i would not recomendto change any configuration related to admin user, i always to make another user for each of task, so you ca track the user activity.
10-15-2019 05:02 AM
thank you
why the passwords are the same?
snmp-server user admin network-admin auth md5 0x7a5c53612f2c14bb9886237c2c251 priv 0x7a5c53612f2c14bb9886237c2c251 localizedkey (from up and running config file)
what does localizedkey mean?
for example if i will change password for the snmp-server user, then it will like this, right?
Nexus(config)#snmp-server user admin auth md5 Passw0rd priv Cisco123 localizedkey
I will not change password. I'm just asking
