06-10-2025 02:44 AM
When testing continuously flying ICMP (Ping) on Nexus 9000 Series, the ping falls out in the pattern because of COPP, does the interface CRC value increase at this time?
06-10-2025 03:44 AM
@king123u - No because CRC errors typically indicate physical layer issues, such as faulty cables, bad transceivers, or electromagnetic interference, rather than CoPP-related packet drops
M.
06-10-2025 04:43 AM
Additionally, a CRC error should preclude the ingress frame from even being considered by CoPP.
Also, CRC errors can be "normal" because there's an expected corruption bit error rate, but it's very, very (very) small. (You can also have corruption not detected by a CRC, at, I believe, even a lower chance.)
If CRC errors higher than spec, and higher than acceptable to you, mitigation should be done.
