07-18-2021 06:48 AM - edited 07-18-2021 06:49 AM
hi,
is it possible to create a redundant/secondary peer-keepalive in a nexus VPC? this is in case the mgmt0 port/cable fails.
the initial/primary peer-keepalive is currently using mgmt0 interface and via management VRF.
i plan to use a L3 SVI for the secondary peer-keepalive link.
interface mgmt0
vrf member management
ip address 192.168.1.1/24
vlan 99
interface vlan 99
vrf member management2
ip address 10.1.1.1/24
vpc domain 1
role priority 10
peer-keepalive destination 192.168.1.2 source 192.168.1.1 vrf management
peer-keepalive destination 10.1.1.2 source 10.1.1.1 vrf management2
07-18-2021 08:52 AM
Strong Recommendations:
When building a vPC peer-keepalive link, use the following in descending order of preference:
1. Dedicated link(s) (1-Gigabit Ethernet port is enough) configured as L3. Port-channel with 2 X 1G port is even
better.
2. Mgmt0 interface (along with management traffic)
3. As a last resort, route the peer-keepalive link over the Layer 3 infrastructure
In a vpc-context I would not advise it anyway , because a 'one-link failure' becomes fuzzy as to whether vpc can be maintained or not.
M.
07-19-2021 04:51 AM
as per the design cisco suggest 1 link is good enough, you do not need more link, to make complex.
