nexus-switches issues no arp-requests.
th.oswald
Hallo all,
I see a very strange behavior on my two nexus switches.
Both are Nexus 5548 with L3-daughter-cards. Both do l2 and l3-switching, ACL-filtering and other things. Furthermore I have a set of servers connected to both switches in a vPC-setup. All in all I do nothing special.
After reloading the primary switch (vpc-primary, root-bridge for all vlans and hsrp-active with preemption for all SVIs) the switche comes back online and after getting up all links and reconverging everthing the network breaks. After a lot of debugging and curses and connection tries and a few additional gray hairs later I have got it to work by pinging all ip-addresses from the switch that I have previously rebooted.
Later I do some tests to find out what was going wrong. I found out that if I clear the arp-cache I will get the same issue. Pinging from server A in one subnet to server B in another subnet doesn't lead to success, because the switch issues no arp-requests. To make it work just ping server B from the switch and all works fine. The switch does arp, the arp-table is updated and the pings from the server A will reach the server B.
Any ideas?
Thomas
Islam Nadim
Can you share the config?
I can post a extraction of the relevant config items.
   - --[ vpc-primary
cfs01# sh run
!Command: show running-config
!Time: Wed Nov 13 08:46:18 2013
version 5.2(1)N1(1b)
cfs eth distribute
vrf context CEPH
vrf context management
  ip route 172.31.0.0/20 172.31.8.190
vlan 14
  name 172.31.50.0/26_CN/NN/OSDs@DMZ
vlan 4080
  name 172.31.48.64/26_NAS.Infrastr@DMZ
spanning-tree vlan 1-129,131-3967,4048-4093 priority 0
udld aggressive
vpc domain 1
  role priority 1
  peer-keepalive destination 172.31.8.179 source 172.31.8.178
  peer-config-check-bypass
  delay restore 150
  peer-gateway
  auto-recovery
  ip arp synchronize
interface Vlan14
  no shutdown
  mtu 9216
  description CN/NN/OSDs@DMZ
  ip access-group acl-vl14-in in
  vrf member CEPH
  no ip redirects
  ip address 172.31.50.61/26
  no ip port-unreachable
  hsrp version 2
  hsrp 3
    authentication md5 key-string 3-14
    preempt delay minimum 30 reload 60
    priority 255
    ip 172.31.50.62
interface Vlan4080
  no shutdown
  mtu 9216
  description NAS.Infrastr@DMZ
  ip access-group acl-vl4080-in in
  vrf member CEPH
  no ip redirects
  ip address 172.31.48.125/26
  hsrp version 2
  hsrp 3
    authentication md5 key-string 3-4080
    priority 255
    ip 172.31.48.126
interface port-channel7
  switchport mode trunk
  switchport trunk native vlan 991
  spanning-tree port type network
  speed 10000
  vpc peer-link
interface port-channel100
  switchport trunk allowed vlan 2,14-19,991,4078-4080
  speed 10000
  vpc 100
interface port-channel102
  switchport trunk allowed vlan 2,14,18,991,1299-1400
  speed 10000
  vpc 102
interface Ethernet1/1
  no cdp enable
  channel-group 100 mode active
interface Ethernet1/3
  no cdp enable
  channel-group 102 mode active
interface Ethernet1/29
  description cfs02_Eth29
  channel-group 7 mode active
interface Ethernet1/30
  description cfs02_Eth30
interface Ethernet1/31
  description cfs02_Eth31
interface Ethernet1/32
  description cfs02_Eth32
interface mgmt0
  description oam01_Gi0/19
  ip address 172.31.8.178/26
cfs01#
   - --[ vpc-secondary
cfs02# sh run
!Time: Wed Nov 13 08:46:05 2013
cfs eth distribute
vrf context CEPH
vlan 14
vlan 4080
spanning-tree vlan 1-129,131-3967,4048-4093 priority 4096
udld aggressive
vpc domain 1
  role priority 2
  peer-keepalive destination 172.31.8.178 source 172.31.8.179
  delay restore 150
  peer-gateway
  auto-recovery
  ip arp synchronize
interface Vlan14
  no shutdown
  mtu 9216
  vrf member CEPH
  no ip redirects
  ip address 172.31.50.60/26
  hsrp version 2
  hsrp 3
    priority 254
    ip 172.31.50.62
interface Vlan4080
  no shutdown
  mtu 9216
  vrf member CEPH
  no ip redirects
  ip address 172.31.48.124/26
  hsrp version 2
  hsrp 3
    priority 254
    ip 172.31.48.126
  speed 10000
  vpc peer-link
  speed 10000
  vpc 100
  speed 10000
  vpc 102
  no cdp enable
  no cdp enable
  description cfs01_Eth29
  description cfs01_Eth30
  description cfs01_Eth31
  description cfs01_Eth32
interface mgmt0
  description oam02_Gi0/19
  ip address 172.31.8.179/26
cfs02#
th.oswald
fuck. The faulty behavior disappears. Just rebooting the nexus-switch. Two days to view a lots of logg-messages, error discovery, tests... For what? For nothing. And now I'm not absolutely sure that the fault will not raise up again. That does not inspire me with confidence.
