10-11-2015 11:06 AM - edited 03-08-2019 02:09 AM
Hi all,
I have a big confusion here, I have a Nexus 9148s this is a fabric and it goes connected to the parent switch my 7706, but the Nexus 9372, is this also a fabric
Can someone help me with this?
Solved! Go to Solution.
10-12-2015 06:25 AM
If you are using the 7706 as your core/parent switches, than they need to be VPCed together and not the 9372s. Also, if you are going to connect the 9372 switches to both 7706 switches, than you want VPC.
10-11-2015 11:36 AM
The 9300 series switches can be deployed as stand-alone switches and don't need to be connected to parent switches, like FEXs.
10-11-2015 02:58 PM
Hello Reza,
I have one more
Thanks!
10-11-2015 03:58 PM
If you are connecting it to only one 7706 than there is no need for VPC. Just a Portchannel. If you are connecting it to 2 different 7706s and they are VPCed together than you want to use VPC this switch.
10-12-2015 05:10 AM
Hi all,
I have two 9372 that will go connected to my two 7706, between my 9372 I have created a
Thanks!
10-12-2015 06:25 AM
10-12-2015 06:31 AM
Only one last question, is there any pdf where I can see what are the best practices about connecting devices, like the example that you and Ganesh just gave me.
Thanks.
10-12-2015 07:52 AM
Have a look at this doc. Its long document, but worth reading it.
http://www.cisco.com/c/dam/en/us/td/docs/switches/datacenter/sw/design/vpc_design/vpc_best_practices_design_guide.pdf
Good Luck
10-11-2015 09:55 PM
Hello Reza, I have one more questions if this can be single stand-alone, I have to connect this to my 7706 will this be better to be a simple port channel or a vpc? Thanks!
For single to single is always to have high capacity redundant port channel links is recommended.
so better to have port channel with 4 or 8 physical link bundle between 9K and 7K.
vPC are been used in scenarios were you want all links to be active and between two uplinks switches.
Hope it Helps.
-GI
Rate if it Helps..
