nexus vpc keep alive failed
Manish Manwal
we are receiving error message in Nexus switch
%VPC-2-PEER_KEEP_ALIVE_RECV_FAIL: In domain 1, VPC peer keep-alive receive has failed.
the vpc peer keep-alive link is a port channel. previously we have shutdown one port in port channel and the we did not received any error message. we have had some doubt about sfp issue so we swapped the sfp but error continues.
switch nexus 3500
Software
BIOS: version 4.2.0
NXOS: version 9.2(2)
BIOS compile time: 09/23/2017
NXOS image file is: bootflash:///nxos.9.2.2.bin
NXOS compile time: 11/4/2018 21:00:00 [11/05/2018 06:11:06]
Hardware
cisco Nexus3500 C3548P-10GX Chassis
Intel(R) Pentium(R) CPU @ 2.00GHz with 4030540 kB of memory.
Processor Board ID FOC253526BK
Device name: abc
bootflash: 3800064 kB
usb1: 0 kB (expansion flash)
usb2: 0 kB (expansion flash)
THANKS
MANISH MANWAL
9 Replies 9
I send you message.
i just replied.
THANKS
MANISH MANWAL
M02@rt37
Hello @Manish Manwal,
Best practices:
The peer keep alive vpc sends heartbeat messages between vPC peers. It is a L3 link, and should be a part of a dedicated VRF. The keep alive link should never be a VLAN on the peer-link.
There are three ways to configure the keepalive link:
  • A single link between the switches, or several links in a port channel
  • A single link between the switches, between the management ports
  • Connecting through existing layer-3 infrastructure, such as an out-of-band management network. This may also use the management ports.
Could you please share the configuration of that peer keep alive on your two Nexus?
Also the output of these commands:
#show vpc
#show vpc peer-keepalive
Trooblshooting vPC: https://www.google.com/url?sa=t&source=web&rct=j&opi=89978449&url=https://www.cisco.com/c/en/us/td/docs/dcn/nx-os/nexus9000/103x/troubleshooting/cisco-nexus-9000-series-nx-os-troubleshooting-guide-release-103x/m-troubleshooting-vpcs.pdf&ved=2ahUKEwjt...
Thanks.
Best regards
feature vpc
vpc domain 1
peer-switch
role priority 4000
system-priority 4000
peer-keepalive destination 192.168.1.2 source 192.168.1.1 vrf vpc-peer-keepalive
delay restore 120
peer-gateway
interface port-channel3
vpc 3
interface port-channel11
vpc 11
interface port-channel12
vpc 12
interface port-channel13
vpc 13
interface port-channel14
vpc 14
interface port-channel15
vpc 15
interface port-channel16
vpc 16
interface port-channel21
vpc peer-link
swc1# sh vpc
Legend:
(*) - local vPC is down, forwarding via vPC peer-link
vPC domain id : 1
Peer status : peer adjacency formed ok
vPC keep-alive status : peer is alive
Configuration consistency status : success
Per-vlan consistency status : success
Type-2 consistency status : success
vPC role : secondary
Number of vPCs configured : 7
Peer Gateway : Enabled
Dual-active excluded VLANs : -
Graceful Consistency Check : Enabled
Auto-recovery status : Disabled
Delay-restore status : Timer is off.(timeout = 120s)
Delay-restore SVI status : Timer is off.(timeout = 10s)
Operational Layer3 Peer-router : Disabled
vPC Peer-link status
id Port Status Active vlans
1 Po21 up 1,22,100
vPC status
Id Port Status Consistency Reason Active vlans
3 Po3 down* Not Consistency Check Not -
Applicable Performed
11 Po11 up success success 100
12 Po12 up success success 100
13 Po13 down* success success -
14 Po14 down* success success -
15 Po15 down* Not Consistency Check Not -
16 Po16 down* Not Consistency Check Not -
Please check "show vpc consistency-parameters vpc <vpc-num>" for the
consistency reason of down vpc and for type-2 consistency reasons for
any vpc.
swc1# sh vpc peer-keepalive
--Peer is alive for : (13865) seconds, (153) msec
--Send status : Success
--Last send at : 2023.08.15 12:43:48 122 ms
--Sent on interface : Po20
--Receive status : Success
--Last receive at : 2023.08.15 12:43:48 123 ms
--Received on interface : Po20
--Last update from peer : (0) seconds, (723) msec
vPC Keep-alive parameters
--Destination : 192.168.1.2
--Keepalive interval : 1000 msec
--Keepalive timeout : 5 seconds
--Keepalive hold timeout : 3 seconds
--Keepalive vrf : vpc-peer-keepalive
--Keepalive udp port : 3200
--Keepalive tos : 192
Switch 2: show running-config vpc
!Time: Tue Aug 15 12:45:01 2023
version 9.2(2) Bios:version 4.2.0
feature vpc
vpc domain 1
peer-switch
role priority 4000
peer-keepalive destination 192.168.1.1 source 192.168.1.2 vrf vpc-peer-keepalive
delay restore 120
peer-gateway
vpc 11
vpc 12
vpc 13
vpc 14
vpc 15
vpc 16
vpc peer-link
SW2# sh vpc
Legend:
vPC domain id : 1
vPC role : primary
Number of vPCs configured : 6
1 Po21 up 1,22,100
vPC status
13 Po13 up success success 22
14 Po14 up success success 22
15 Po15 down* success success -
16 Po16 down* success success -
any vpc.
swc2# sh vpc peer-keepalive
--Peer is alive for : (12986) seconds, (264) msec
--Last send at : 2023.08.15 12:45:13 244 ms
--Last receive at : 2023.08.15 12:45:13 245 ms
--Last update from peer : (0) seconds, (103) msec
--Destination : 192.168.1.1
THANKS
MANISH MANWAL
Thanks @Manish Manwal,
vPC peer keepalive seem to be OK!
Best regards
M02@rt37
Also please share the configuration of Po20.
Best regards
Switch2:
interface port-channel20
description s1 po20 :: po20 s2 VPC peer-keepalive
no switchport
mtu 9216
vrf member vpc-peer-keepalive
ip address 192.168.1.1/30
_____________________________________________________
SWitch 1:
description s2 po20 :: po20 s1 VPC peer-keepalive
no switchport
mtu 9216
ip address 192.168.1.2/30
THANKS
MANISH MANWAL
@Manish Manwal,
Your vpc peer keepalive seems to be OK @Manish Manwal, regarding the output you share.
Best regards
M02@rt37
@Manish Manwal, come back to us after Cisco TAC advices/feedback.
Thanks.
Best regards
