01-29-2013 08:50 AM - edited 03-07-2019 11:23 AM
Hello everybody,
Does Nexus5K (N5K-C5596UP-FA) have support or will have support to 10G-BaseT?
Does Cisco have any GLC for 10G-BaseT for Nexus5k series?
Solved! Go to Solution.
01-29-2013 09:24 AM
I had not seen that. The second option is still viable, or you could add a N2K-C2232TM-E FEX to it to give you 10G Base-T support.
01-29-2013 09:10 AM
You can always add a N55-M12T 12 port 10G-BaseT expansion module. If you have a requirment for more10G-BaseT then SFP+, you could use a N5K-C5596T-FA and add N55-M16UP expansion modules as needed.
01-29-2013 09:14 AM
01-29-2013 09:24 AM
01-29-2013 09:36 AM
Ok Gregory, the second option is not good because I don´t have a N5K-C5596T-FA.
But I think N2K-C2232TM-E could be used.
Thanks.
