05-28-2013 05:48 AM - edited 03-07-2019 01:36 PM
I am using N5k to connect with IBM Blade server (IBM Switch)
Note : IBM blade chassis 1 gig port (inbuilt IBM Switch) is directly connected to Nexus5k Switch (Manually assign speed 1 gig)
I have created port-channel and made it trunk. (Chassis port also in port channel and trunk)
Nexus5k connected port is showing up but when I am running command show int port-channel20 it showin down
port-channel20 is down (No operational members)
Members in this channel: Eth1/21, Eth1/22, Eth1/23, Eth1/24
In Second scenario i have connectd cable on 1 cisco swich and making port channel and connected with nexus it is showing ok.
but having issue with IBM Blade server (IBM switch).
Please help.....
05-28-2013 06:02 AM
Can you post configs from both the 5k and IBM switch?
05-28-2013 06:35 AM
do "sh eth sum", what you see under ports?
Connect both cables and check again.
Make sure that configuration on both ends is using the same channel protocol.
