10-22-2012 11:43 PM - edited 03-07-2019 09:37 AM
since yesterday we got a couple of this logging-events:
Oct 23 08:09:01 bciscon7k01 : 2012 Oct 23 06:09:01 UTC: %ARP-3-INVAL_HDR_PROT_TYPE: arp [4290] Found incorrect protocol type in ARP header: 0x1000
Oct 23 08:09:47 bciscon7k01 : 2012 Oct 23 06:09:47 UTC: last message repeated 2 times
Oct 23 08:10:53 bciscon7k01 : 2012 Oct 23 06:10:53 UTC: last message repeated 3 times
Oct 23 08:12:04 bciscon7k01 : 2012 Oct 23 06:12:04 UTC: last message repeated 2 times
the system is working for 120 days without this event.
our System:
Hardware
cisco Nexus7000 C7009 (9 Slot) Chassis ("Supervisor module-1X")
Software
BIOS: version 3.22.0
kickstart: version 6.0(4)
system: version 6.0(4)
I can post the configuration, if it is requested.
I haven't found an error description or a bug report. Can anybody explain this explain this event? And do we have to react?
Kind regards
andreas
Solved! Go to Solution.
10-23-2012 02:24 AM
Hi Andreas,
This is kind of informational message about the receipt of such an ARP packet and has no impact on the switch operation. The Nexus 7K itself is not the cause of the message. It just reports the invalid arp packet being received by the Nexus 7000.
This issue is almost matching with known Bug CSCtt06010 - Fix the syslog string ARP-3-INVAL_HDR
Symptom:
Syslog seen with ARP-3-INVAL_HDR.
Conditions:
Workaround:
None.
This message indicates that a device in your network is sending ARP packets with a hardware type '6' (instead of 1 for Ethernet) which is incorrect. The protocol type is 2048 (0x800 in hex), which is correct, however the message is printed when either value is wrong.
Example:
Nexus7010# sh ip arp statistics
ARP packet statistics for context default
Sent:
Total 228979, Requests 114572, Replies 1, Requests on L2 0, Replies on L2 0,
Gratuitous 114406, Tunneled 0, Dropped 0
Send packet drops details:
MBUF operation failed : 0
Received:
Total 119759, Requests 1, Replies 162, Requests on L2 0, Replies on L2 0
Proxy arp 0, Local-Proxy arp 0, Tunneled 0, Dropped 119596
Received packet drops details:
Appeared on a wrong interface : 0
Incorrect length : 0
Invalid protocol packet : 0
#ethanalyzer local interface inband capture-filter arp display-filter "arp.proto.type == 0x1000" limit-captured-frames 1000000
Refer:
Cisco Nexus 7000 Series Architecture: Built-in Wireshark Capability for Network Visibility and Control
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9402/ps9512/white_paper_c11-554444.html
Aru
**** Please rate if the post is useful ***
10-23-2012 02:24 AM
Hi Andreas,
Symptom:
Conditions:
Workaround:
None.
Example:
Sent:
Received:
Refer:
Aru
10-23-2012 02:56 AM
Hi Aru,
thanks for your detailed answer. I'll try to capture the traffic and determine the address.
So on your answer was very useful and let me relieve stress.
Andreas
10-23-2012 03:21 AM
Hi Andreas,
Thanks for your kind response. Its my pleasure to support
Aru
