Highlighted
Beginner
Nexux 7k Port-channels Not Establishing on Downstream Switches
We have a pair if Nexus 7k's, c7010s, running version 6.2(12). The inventory is as follows:
Mod  Ports  Module-Type                         Model              Status
1    48     1000 Mbps Optical Ethernet Module   N7K-M148GS-11      ok
2    8      10 Gbps Ethernet XL Module          N7K-M108X2-12L     ok
3    8      10 Gbps Ethernet XL Module          N7K-M108X2-12L     ok
4    8      10 Gbps Ethernet XL Module          N7K-M108X2-12L     ok
5    0      Supervisor Module-1X                N7K-SUP1           active *
6    0      Supervisor Module-1X                N7K-SUP1           ha-standby
7    8      10 Gbps Ethernet XL Module          N7K-M108X2-12L     ok
8    32     1/10 Gbps Ethernet Module           N7K-F132XP-15      ok
9    32     1/10 Gbps Ethernet Module           N7K-F132XP-15      ok
The fiber is single mode. The transceiver is a SFP-10GBase-LRM on both sides.  When we try to setup a new port-channel, it doesn't establish. We have determined that it is not cable fiber related.
Please let us know if there is any known issue with port-channels on N7k's or where we should search for a solution.
6 REPLIES 6
Highlighted
Can you post the config for each port-channel and its member interfaces on each N7K?
Can you also provide show lacp counters interface port-channel #?
Highlighted
N7K-1 (The one that connects)
interface port-channel163
description vPC to AA03-TC30
switchport
switchport mode trunk
switchport trunk native vlan 996
switchport trunk allowed vlan 1,25-28,50-64,123,223,802,989,994
switchport trunk allowed vlan add 996
vpc 163
port-channel163
Ethernet4/4 82857 89290 0 0 0
N7K-2 (The one that doesn't connect)
switchport
vpc 163
no lacp in list
Highlighted
Can you post the configs for the interfaces that are supposed to be bundled in Po163?
Highlighted
N7K-1 (Connected)
interface Ethernet4/4
description AA-03
switchport
channel-group 163 mode active
no shutdown
N7K-2 (Doesn't Connect)
description AA-03
switchport
no shutdown
AA-03
interface Port-channel1
end
interface TenGigabitEthernet1/0/1
channel-group 1 mode passive
end
interface TenGigabitEthernet1/0/2
end
Highlighted
Can you check the same lacp counter information from the remote side?
Highlighted
VIP Mentor
what is the output of:
show port-channel compatibility-parameters
Can you try 'on' mode on both sides ?
Content for Community-Ad
