NLB on nexus 9K
ranga83
I have a requirement to setup IGMP multicast mode on Nexus 9k switches to support Microsoft NLB.
I have gone through the article  https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus9000/sw/9-x/multicast/configuration/guide/b_Cisco_Nexus_9000_Series_NX-OS_Multicast_Routing_Configuration_Guide_9x/b_Cisco_Nexus_9000_Series_NX-OS_Multicast_Routing_Configuration_Guide_9x...
and found out that "hardware profile multicast nlb" should be enabled on 9k switches to support IGMP multicast mode.
however, my switches don't support that command.
these are the options I have when I put that commnd.
(config)# hardware profile multicast ?
flex-stats-enable            Enable real time stats
max-limit                        Maximum limit for multicast entries
rpf-check-optimization   RPF Check optimization on Monticello ASIC
service-reflect                Service-reflect settings
show version
Software
BIOS: version 07.64
NXOS: version 7.0(3)I7(5)
BIOS compile time: 05/17/2018
NXOS image file is: bootflash:///nxos.7.0.3.I7.5.bin
NXOS compile time: 8/28/2018 2:00:00 [08/28/2018 09:51:46]
Hardware
cisco Nexus9000 93180YC-EX chassis
Intel(R) Xeon(R) CPU @ 1.80GHz with 24633480 kB of memory.
Kernel uptime is 124 day(s), 22 hour(s), 9 minute(s), 9 second(s)
Last reset
Reason: Unknown
System version: 7.0(3)I7(5)
Service:
plugin
Core Plugin, Ethernet Plugin
Active Package(s):
Has anyone seen this kind of issue?
Viduna Rangana
Mark Malone
i have same switches in my DC running nxos.7.0.3.I5.5.bin i only have max-limit as an option , the doc staes 9300 EX but doesnt say what version, im thinking its a certain version required for the EX version
you could cehck the latest configuration guide for tht platform software version see if the commands is available
jecker
Were you able to resolve this issue?
