NM-8A and wic-2t , what cable I need?
chuang123
hi all,
I bought a used 2610xm and install with NM-8A as my frame relay switch.
and my 1841 has wic-2t installed. but I don't know which cable I need for connecting both device via serial?
I checked datasheet, but still not sure which cable I need.
CAB-SS-V35MT V.35 DTE 10 feet (3 meters) Male
CAB-SS-V35FC V.35 DCE 10 feet (3 meters) Female
does that mean I need one cable mail connect to wic-2t, and another female cable connect to NM-8A, and then connect both cable together?
can someone help? I need to buy few for my ccnp lab.  don't wanna buy wrong cable.
BRs,
Johnny
Reza Sharifi
You just need the DTE/DCE crossover cable.
They are pretty cheap these days.
have a look at this
http://www.amazon.com/Monoprice-3ft-DB60-Crossover-Cable/dp/B001TN0S8G
hi Reza,
but my wic-2t is a smart serial connector, do you which cable I should buy?
Ok, if your interface is smart serial interface, then you need smart serial crossover:
http://www.cablesandkits.com/cisco-smart-serial-crossover-cable-6-cabss2626x6-p-872.html?gclid=CKP01u3q97YCFYOK4AodHXwAhg
I found solution should be DB60 to SS cable. and it's very expansive. 15euro each. and I need to buy 11cable for my ccie lab.
thanks for your help
