NME-16ES-1G EtherSwitch won't communicate with 3745 host
Paul Robichaud
Beginner
Beginner
I have a Cisco 3745 Router with a NME-16ES-1G EtherSwitch module.  For some reason, the NM won't communicate with the 3745 host via the virtual Gigabit Ethernet interface that supposedly connects them.  It does, however, communicate via the internal console port, which I can access via the command "service-module g2/0 session". I've configured the virtual GigE Interfaces on both the 3745 host and the EtherSwitch module per the example at http://www.cisco.com/en/US/products/hw/modules/ps2797/products_configuration_example09186a0080810449.shtml .  I don't receive any error from either the switch module or router on bootup.  I've pasted the configurations for both the host and the module below:
3745 Router:
Current configuration : 993 bytes
version 12.4
service password-encryption
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
username paul privilege 15 password
archive
log config
  hidekeys
interface FastEthernet0/0
ip address 10.0.0.250 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet2/0
ip address 192.168.100.1 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
logging synchronous
line 65
no activation-character
no exec
transport preferred none
transport input all
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
line aux 0
line vty 0 4
login local
end
Switch module
Current configuration : 2883 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname Switch
boot-start-marker
boot-end-marker
enable password
no aaa new-model
system mtu routing 1500
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet1/0/1
interface FastEthernet1/0/2
interface FastEthernet1/0/3
interface FastEthernet1/0/4
interface FastEthernet1/0/5
interface FastEthernet1/0/6
interface FastEthernet1/0/7
interface FastEthernet1/0/8
interface FastEthernet1/0/9
interface FastEthernet1/0/10
interface FastEthernet1/0/11
interface FastEthernet1/0/12
interface FastEthernet1/0/13
interface FastEthernet1/0/14
interface FastEthernet1/0/15
interface FastEthernet1/0/16
interface GigabitEthernet1/0/1
no switchport
ip address 10.0.0.251 255.255.255.0
interface GigabitEthernet1/0/2
no switchport
ip address 192.168.100.2 255.255.255.0
interface Vlan1
no ip address
shutdown
ip http server
logging esm config
line con 0
line vty 0 4
login local
line vty 5 15
login
end
Any help or suggestions would be greatly appreciated.
glen.grant
Advisor
Advisor
    Config looks right, what address are you trying to hit .  I would try to configure an address on one of the ports on the switch  and get it in a up/up condition and see if you can get to that , may not let you get to those virtual internal addresses.
Recognize Your Peers
