Join Customer Connection to register!
916
sivaprakasam81
Beginner
NMS: CAT6500 : Sup720 : MIB-OIDs
Hi All,
We are running a network management system (NMS) that executes applications then monitor and control managed devices. Like Network elements -- routers,Switches.
We need MIB-OIDs for Cat6500,Sup720,Fan tray and power module. OID identifies a variable that can be read or set via SNMP.
Thank you,
2 REPLIES 2
Sushil Kumar Katre
Rising star
Hi Siva,
You can browse through the MIB Locator tool - http://tools.cisco.com/ITDIT/MIBS/MainServlet
Once you search the relevant MIB you download the same and browse too find the OID.
-> Sushil
mbroger
Beginner
i have searched the Cisco MIBs and testets it with Whatsup V12.4 and it works.
here die MIB-OIDs for you
Cisco 65xx Fan TRAY
1.3.6.1.4.1.9.9.13.1.4.1.3 Instance 3
Cisco 65xx Power Supply 1
1.3.6.1.4.1.9.9.13.1.5.1.3 Instance 1
Cisco 65xx Power Supply 2
1.3.6.1.4.1.9.9.13.1.5.1.3 Instance 2
and here also the 2 MIBs for the Fans in the Power Supplys
Cisco 65xx Power Supply 1 FAN
1.3.6.1.4.1.9.9.13.1.4.1.3 Instance 1
Cisco 65xx Power Supply 2 FAN
1.3.6.1.4.1.9.9.13.1.4.1.3 Instance 2
Greeds Feichti
