10-04-2016 06:28 PM - edited 03-08-2019 07:40 AM
I have a Cisco 2960S uplinked to a Dell N4032 via 10G SFP+. If I uplink via 1G port to an N3024 Dell in my rack, the DHCP traffic passes to and from the server connected to the N4032. But if I use the 10G port on the Cisco it seems no DHCP traffic passes. Other traffic seems to pass fine. All three switches use the same subnet, so no routing from one subnet to another should be needed.
Ideas?
10-04-2016 06:43 PM
Are the interfaces configured the same? Show output of show run interface and show interface for both interfaces.
John
10-04-2016 07:50 PM
Hmm, I take it back. Neither the TenGig nor the Gig ports seem to be passing DHCP traffic. I did some additional experimenting. If I wire a node directly to a Gig interface port on the Dell N3024 I get PXE boot.
Additional data point.. I didn't have this problem with the HP switch I used prior. But we wanted a 10G uplink if possible, and we had the Cisco on hand. I guess the question remains though if the Cisco is blocking the traffic, or if the Dell is.
Switch#show run interface TenGigabitEthernet1/0/1
Building configuration...Current configuration : 41 bytes
endSwitch#show interface TenGigabitEthernet1/0/1
TenGigabitEthernet1/0/1 is up, line protocol is up (connected)
Hardware is Ten Gigabit Ethernet, address is 34bd.c8a0.9fb3 (bia 34bd.c8a0.9fb3)
MTU 9000 bytes, BW 10000000 Kbit/sec, DLY 10 usec,
Keepalive not set
Full-duplex, 10Gb/s, link type is auto, media type is SFP-10GBase-CX1
input flow-control is off, output flow-control is unsupported
Last input 00:00:00, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 139000 bits/sec, 211 packets/sec
5 minute output rate 14985000 bits/sec, 1249 packets/sec
4702107620 packets input, 1600923369535 bytes, 0 no buffer
Received 778386296 broadcasts (777897180 multicasts)
0 watchdog, 777897180 multicast, 0 pause input
16154093535 packets output, 21860091136382 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
637018 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
Switch#
10-04-2016 09:46 PM
hi,
Are you using anything like dhcp snooping in your environment?
John
10-05-2016 10:34 AM
No
10-06-2016 04:29 PM
Could be bug in ios. What ios version are you running? Have you tried another ios version.
John
10-06-2016 08:18 PM
Some clarity here, please. IS pure DHCP apparently working for IP addresses across the board, in all situations, and just PXE boot failing?
The PXE boot process is more sensitive to timing than typical DHCP. Workstations "connect" to the network and activate the port, and retry for an IP address if they don't get one immediately. PXE boot will time out and fail in the same situation. Just for fun, try using a cheap minihub in front of one of the switches, that you then connect a PXE workstation you are building. If that works, you have to get the negotiation timing reduced on your switchports.
Ways to do that?
- spanning-tree portfast
- switchport mode access (don't let it negotiate trunking !)
There may be others (I think there are a total of about 5 negotiations that take place every time a switch "sees" a device connect; some like spanning-tree can take 30 seconds.
10-12-2016 01:45 PM
See my followup for the ultimate solution.
10-05-2016 08:12 PM
I should add that what is actually failing is PXE boot. Which presumably means that there are 2 or 3 different ports involved in the traffic getting blocked. I'm not seeing DHCP offer/ack in the logs, but it's actually port 4011 initially?
10-05-2016 03:07 PM
I have reset the switch to factory defaults. I still can't get any DHCP traffic through. I have no DHCP snooping running anywhere.
10-06-2016 06:59 PM
Ultimately I replaced the Cisco with a much "dumber" HP switch we had, and it still failed.
The answer was to find vlan1 layer 2 dhcp relay option in the upstream Dell switch.
