Highlighted
Beginner
No Traffic under Interface Vlan X on Nexus 7009
Hello Everybody!
I got an issue with a Nexus 7009 when i try to get info about traffic on all the intefaces vlan.
I got an Nexus 7010 and everything is ok
on the 7010 the NX-OS is  n7000-s1-dk9.5.2.5.bin (cisco Nexus7000 C7010 (10 Slot) Chassis ("Supervisor module-1X"))
on the 7009 the NX-OS is n7000-s2-dk9.6.1.2.bin (cisco Nexus7000 C7009 (9 Slot) Chassis ("Supervisor module-2"))
There are the output of every one:
7010
sh interface vlan 100
Vlan100 is up, line protocol is up
Hardware is EtherSVI, address is  64a0.e73e.4a43
MTU 9216 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive not supported
ARP type: ARPA
Last clearing of "show interface" counters 18:50:11
60 seconds input rate 278 bits/sec, 0 packets/sec
60 seconds output rate 6890624 bits/sec, 581 packets/sec
Load-Interval #2: 5 minute (300 seconds)
   input rate 310 bps, 0 pps; output rate 5.51 Mbps, 512 pps
L3 Switched:
   input: 6377335 pkts, 629779216 bytes - output: 2324464692 pkts, 194832837128
3 bytes
L3 in Switched:
   ucast: 858960 pkts, 88978466 bytes - mcast: 5518375 pkts, 540800750 bytes
L3 out Switched:
   ucast: 2324464692 pkts, 1948328371283 bytes - mcast: 0 pkts, 0 byte
show inter vlan 100 counter
Port                                 InOctets                      InUcastPkts
Vlan100                            629456345                            858512
Port                              InMcastPkts                      InBcastPkts
Vlan100                              5515532                                --
Port                                OutOctets                     OutUcastPkts
Vlan100                        1947750766181                        2322427231
Port                             OutMcastPkts                     OutBcastPkts
Vlan100                                    0                                --
7009
Hardware is EtherSVI, address is  8478.ac58.dec3
Description:
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
ARP type: ARPA
I´ve tried to clear counter on all interfaces and says that counters have never been cleared
Do any know something about the issue? I mean, bug or something?
I need that info because on my monitor tool i can't see any traffic...
Thanks in Advance!
6 REPLIES 6
Highlighted
you were able to solve it?
Thank you.
BR,
NS
Highlighted
Hi, Are you concerned about not seeing any traffic for vlan 100 in NX 7009 ?
Execute the below commands and paste the full output here.
Show interface Vlan 100 - Do you see Input/Output rate ?
Show interface vlan 100 counter - Do you see any counter values incrementing ?
Highlighted
Hi Chandan,
in the show int vlan 100 we see traffic, but with show interface vlan 100 counter we don't see any counters incrementing. We see this also for the other SVIs.
In our case is an NX 9504.
BR,
NS
Highlighted
Please paste full output of below commands :
Highlighted
What was the solution, I am having similar issue on a 7009?
Highlighted
Sorry Angelo, i don't remember if was a solution for this issue, i think we had to upgrade the IOS version, but i really don´t remember...
Content for Community-Ad
