12-11-2019 03:26 PM
Hi guys.
I have a problem where I am not able to telnet into my route
Both my laptop and router are connected to the same switch.
I am able to telnet into my switch but not to my router.
Whenever I try to open a telnet session I get a message stating that the connection has been refused.
I've attached the config of my router to this post.
Hope some one is able to help me out.
Solved! Go to Solution.
12-11-2019 03:31 PM
make sure you created a username and password and enable transport telnet
line vty 0 4
transport input telnet ( telnet is not advised , sugested is SSH)
12-11-2019 03:31 PM
line vty 0 4
12-11-2019 06:47 PM
12-11-2019 06:57 PM
Hi @stephenp85
line vty 0 4 password cisco login transport input none <-- This line prevents connections to the vty lines.
Try changes:
line vty 0 4
no transport input none
Or if you want to allow only telnet
line vty 0 4
