12-15-2004 09:07 AM - edited 03-05-2019 11:21 AM
I am looking for the proper config settings to run a traffic generator into 1 port, then out 3 others with no restrictions. For some reason xmission has been cut short by my catalyst 2900, whereas it should continue flowing through the switch without restriction. I'd appreciate a step-by-step from POST to completion of this particular config.
12-15-2004 12:06 PM
can you post the configuration of your 2950 as you have it now ?
GP
01-03-2005 08:33 AM
sorry, but i cannot. would you be so kind as to show the commands it would take to set up a switch to do the whole "in 1, out 3" scenario?
01-13-2005 03:07 PM
Looks to me like you want to do port monitoring. It should look something like this:
FastEthernet xx/xx (port to be monitored)
FastEthernet xx/xx
Port Monitor FastEthernet xx/xx (port you want to monitor)
FastEthernet xx/xx
FastEthernet xx/xx
This should allow someone plugged into any of the latter 3 ports to see all traffic on the first port. Hope this helps.
Rick
01-14-2005 06:00 AM
thanks so much for your reply, it's exactly what i was looking for.
cheers,
MS
