NPE-300 7206VXR boot failure
tresatony
I am getting following error when I boot 7206VXR router with NPE-300 from rommon
*** Bus Error (Load) Exception ***
Access address = 0x826e5bc1
PC = 0x8000af3c, Cause Reg = 0x1c, Status Reg = 0x3040d003
monitor: command "boot" aborted due to exception
Please advice.
Thank you,
Tresa
plumbis000
Try a different IOS image to start with, see if you can get anywhere with that. Might also be an issue with the boot media.
You mean issue with flash ?
Could it be a problem with I/O controller ?
or could it be a problem with boot loader image. Only somtimes this error is dispalyed when booting from rommon. The booting is not booting with IOS image . No error message I am getting at that time. The booting stops and by break sequence I can enter rommon and boot with same IOS I have given in boot system command.
Tresa
I've seen a problem very similar to that before and I think it's related to the flash disk, but I'm not 100% sure. If you have the time/ability I'd try either formatting and reloading the IOS onto the flash or trying a new disk just for testing.
