Showing results forĀ
Search instead forĀ
Did you mean:Ā
ntp not working
Manish Manwal
we have  one switch cisco 3850 configured as a ntp master. when we update another switch time form ntp server its update time but, its time is diffrent form our ntp master switch.
in ntp master we use just ntp master command and another switch we use ntp master switch loopback ip as a ntp server.
ntp server x.x.x.x
can someone give me  of ntp server and peer full configuration.
THANKS
MANISH MANWAL
rasmus.elmholt
Level 7
Level 7
Remember to set the clock on the 3850 and then the ntp master command.
If the 3850 is already configured with as a NTP client( ntp server x.x.x.x command) it will automaticaly become NTP server as well.
What does the show ntp ass command says on the ntp client? is it syncing?
And is the 3850 listening on port 123 UDP?
#show udp
Proto Remote Port Local Port In Out Stat TTY OutputIF
17 --listen-- 10.xx.xx.1 123 0 0 13001001 2
17(v6) --listen-- FE80::1 123 0 0 13020001 2
I find this best practise very useful: https://www.cisco.com/c/en/us/support/docs/availability/high-availability/19643-ntpm.html
7 Replies 7
Leo Laohoo
If the 3850 is synchronizing NTP with an NTP server, don't (ever) use the command "ntp master".
there is no interface vlan 1. many vlan but not 1 , and switches are in different vlan.
mr georg pauwen whatever configuration you give me it not working.
THANKS
MANISH MANWAL
In addition to Leo's remark, below is what could work. It is a fairly simple setup:
NTP client
clock timezone GMT +1
clock summer-time PDT recurring
ntp server 1.1.1.1
interface GigabitEthernet 0/0
ntp broadcast
NTP Master
ntp master
interface Vlan 1
ntp broadcast
not working.
some other help needed
mr. Georg Pauwen
THANKS
MANISH MANWAL
What is not working ?, can you post the configuration you have done.
show output related to  show ntp  Server and client to understand the issue.
BB
post the full configs of both switches as well as the output of 'show ntp status'...
rasmus.elmholt
Level 7
Level 7
#show udp
