NTP-to-PTP Gateway on Stratix 5400 aka Cisco IE4000/IE5000: Multiple VLANs? Multicast routing?
BRIAN SEKLECKI
All:
Per my other post on this matter:
Can someone from Cisco IE4000/5000 engineering team please confirm:
PTP traffic generated by the NTP-to-PTP gateway feature sets the Muticast IP packets TTL value to 1, preventing packets from being Layer3 switched/routed between VLANs?
Any plans in future IOS on the IE4000/5000/Stratix 5400 to allow multiple VLANs? Or specify the PTP TTL?
----------- Sample Config -----------
Even if I perform a static join:
vlan 100
  name Ring-Native-and-Mgmnt
vlan 200
  name Isolated-Segment-1
vlan 201
  name Isolated-Segment-2
vlan 202
  name Isolated Seg....
int range Gi1/1-2
  description Facing-PRP-Ring
  switchport mode trunk
  switchport trunk allowed vlan 100,201,202,203
  switchport trunk native vlan 100
  ptp vlan 100
ip multicast-routing distributed
int range vlan 100,201,202,203
  ip pim spare-dense-mode
int vlan100
   ip address 10.1.100.1 255.255.255.0
   ip igmp static-group 224.0.129 source 10.1.100.1
0 Replies 0
