Numbering when removing a switch from a stack
Mottok
Hi, just a simple question but want to double check before doing this for the first time.
We have a stack of five 3650 switches (as per below) and want to remove the 2nd switch (TsStck-3650-02). Question is, how will this affect the remaining stack in terms of numbering and priority? Many thanks.
TsStck-3650-01      -   priority 1
TsStck-3650-02      -  priority 14
TsStck-3650-03      -  priority 13
TsStck-3650-04      -  priority 12
TsStck-3650-05      -  priority 11
luis_cordova
Hi @Mottok
Neither numbering nor priority should be affected. Assuming that switch 2 is the active one, then the standby switch would take on the active role.
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3650/software/release/16-1/configuration_guide/b_161_consolidated_3650_cg/b_161_consolidated_3650_cg_chapter_01010001.pdf
luis_cordova
Hi @Mottok
Thanks very much for your quick reply. I can't view that link for some reason so to confirm, when I remove the switch then issue the "no switch xx provision command", will the stack look like below? Many thanks.
TsStck-3650-03 - priority 13 (Now Active)
Hi @Mottok
Indeed, the switch with the second highest priority(actual standby) should take the role of active.
In any case, take into account those indicated in the link:10F0FCA0-939B-4DA1-89C3-3B2212E0F478.png
That's great, thanks very much for all your help.
