nvram errors on 3560-G
jefflynt5930
i went to save mem on switch and i am getting this error? i am assuming there is not enough space or something? also, what can i delete?
Building configuration...
nv_done: unable to open "flash:/config.text.new"
nv_done: unable to open "flash:/private-config.text.new"
Error writing new block-fs file "flash:/multiple-fs.new"[OK]
s1.macon-toy.butler#sh flash
Directory of flash:/
    2  -rwx         976  Feb 21 2011 22:20:56 -05:00  vlan.dat
    3  drwx        1600  Feb 28 1993 19:00:20 -05:00  crashinfo_ext
    4  -rwx         512  Jul 19 2014 13:21:39 -04:00  multiple-fs.new
    5  drwx         192  Feb 28 1993 19:06:36 -05:00  c3560-ipbase-mz.122-35.SE5
  463  -rwx       32370  Jun 21 2011 19:58:39 -04:00  CCP_backup
  464  -rwx       32221  Mar 15 1993 02:40:37 -04:00  config.text
  465  -rwx        2072  Mar 15 1993 02:40:37 -04:00  multiple-fs
  467  drwx       12544  Feb 28 1993 19:00:10 -05:00  crashinfo
15998976 bytes total (0 bytes free)
Graham M
You can most likely delete the flash:crashinfo and flash:crashinfo_ext diectories as they are probably taking up the remaining space.
BTW I would recommend checking the contents of those directories to see why there are logged crashes. You may have a software fault based on the version of IOS the switch is running.
Graham M
