Cisco Community Designated VIP Class of 2020
146
Beginner
NX-56128P-ISSU
When i do "show install all impact kickstart bootflash:n6000-uk9-kickstart.7.1.1.N1.1.bin system bootflash:n6000-uk9.7.1.1.N1.1.bin" , the result shows "DESRUPTIVE"
switch# show install all impact kickstart bootflash:n6000-uk9-kickstart.7.1.1.N1.1.bin system bootflash:n6000-uk9.7.1.1.N1.1.bin
Verifying image bootflash:/n6000-uk9-kickstart.7.1.1.N1.1.bin for boot variable "kickstart".
[####################] 100% -- SUCCESS
Verifying image bootflash:/n6000-uk9.7.1.1.N1.1.bin for boot variable "system".
Verifying image type.
Extracting "system" version from image bootflash:/n6000-uk9.7.1.1.N1.1.bin.
Extracting "kickstart" version from image bootflash:/n6000-uk9-kickstart.7.1.1.N1.1.bin.
Extracting "bios" version from image bootflash:/n6000-uk9.7.1.1.N1.1.bin.
Performing module support checks.
Notifying services about system upgrade.
Compatibility check is done:
Module  bootable          Impact  Install-type  Reason
     1       yes      disruptive         reset  Non-disruptive install not supported if L3 was enabled
     3       yes      disruptive         reset  Non-disruptive install not supported if L3 was enabled
Images will be upgraded according to following table:
Module             Image         Running-Version             New-Version  Upg-Required
     1            system            7.0(5)N1(1a)             7.1(1)N1(1)           yes
     1         kickstart            7.0(5)N1(1a)             7.1(1)N1(1)           yes
     1              bios      v2.7.0(03/12/2014)      v3.0.0(09/22/2014)           yes
     1         power-seq                    v1.0                    v1.0            no
     1  fabric-power-seq                    v2.0                    v2.0            no
     3         power-seq                    v5.0                    v2.0            no
     1   microcontroller               v0.0.0.44               v0.0.0.44            no
I believe there is no Layer 3 feature used in this switch. It is an Access switch and it shows as layer 3 not supported. I read other posts related to this. It was mentioned Layer 3 license should be disabled. If so how to disable layer 3 license and where to check whether layer 3 license is enabled or not. Please suggest. Thanks in advance.
2 REPLIES 2
VIP Mentor
Re: NX-56128P-ISSU
couple of tips in this link , make sure no l3 features are enabled
https://www.packetmischief.ca/2015/12/15/avoiding-an-issue-on-the-nexus-5000/
i also ran through this with another user before maybe something in the post that could help
https://supportforums.cisco.com/t5/lan-switching-and-routing/license-feature-in-cisco-5672-up/td-p/2956035
VIP Expert
Re: NX-56128P-ISSU
After removing the layer-3 license, you have to reboot the chassis and so that will cause downtime anyway.  So, why not have a maintenance window and run the "install all" command and upgrade the box without disabling anything and be done with it?
Content for Community-Ad
