object-group ip port configuration
ziqex
Level 4
Level 4
I wanted to create object-group ip port OBJ_WEB_PORTS with the content of:
eq 443 - this is accepted
source eq 443 - this does not work
Unfortunately, the syntax is not valid. Device: Cisco C6880-X-LE
For 9K switches (C9300-24T) there is no issues with it:
object-group service OBJ_WEB_PORTS
tcp eq www
tcp eq 443
tcp source eq 443
How can I create source eq 443 inside object-group ip port OBJ_WEB_PORTS
What would be the equivalent command?
Thank you.
Daniel
when apply this service object group use source or destination,
Under object group you can only select the port.
balaji.bandi
what version of code running - Cisco C6880-X-LE
BB
System image file is "bootdisk:c6880x-ipservicesk9-mz.SPA.155-1.SY5.bin"
