09-19-2009 08:21 AM - edited 03-06-2019 07:47 AM
Will a 3750 Metro Ethernet switch support OER/PfR on the enhanced services ports? I don't see it listed in Advanced IP SERVICES/IP SERVICES+
09-20-2009 05:03 AM
Hello Gray,
you can use the feature navigator tool for this kind of search
do search by feature
type OER
then looking at the list of supporting platforms you can find sw based routers C4500, C6500 , ME6524 but no ME3750 is present.
so the answer should be negative.
Hope to help
Giuseppe
09-21-2009 05:41 AM
Hi Giuseppe,
Thank you for taking the time to help me. I used the feature navigator as you instructed but I did not come up with the same result. I could not verify that the ME6524 will support OER or OER BGP Inbound Optimization as I think it is called in later releases. I have tried many times. What am I doing wrong?
09-21-2009 10:27 AM
Hello Gray,
we did two different searches I searched for just OER that I guess is the basic feature.
I just tried to give you a method for searching, you know better then me what you need in your scenario.
Hope to help
Giuseppe
09-21-2009 10:47 AM
Hi Giuseppe,
OK thanks. I have found more info on OER Border only functionality.
Thank you!
