Showing results forĀ
Search instead forĀ
Did you mean:Ā
One VLAN won't communicate between switches even though the others do.
jakeparsons03
So I have 2 networks that are connected via L2 Switches. Each network has their own router. From top down it goes Router>L2 Switch> Hosts. The configuration is  the same for each network. All of my VLANs will connect to the other network through the L2 Switch except for 1 (VLAN 10). I was wondering if anyone had similar issues. I can ping from the host, through the router and back  to the switch on the VLAN that connects the switches together (VLAN 40) but when I try to ping the ip for VLAN 40 on the other network the packet drops. I've attached a picture of the network and highlighted the non-working host.
The following is the config file for the switch on the first network (one attached to the non-working host).
Current configuration : 1635 bytes
version 12.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Switch
spanning-tree mode pvst
interface FastEthernet0/1
interface FastEthernet0/2
switchport trunk allowed vlan 10,20,30,40
switchport mode trunk
interface FastEthernet0/3
switchport access vlan 30
switchport mode access
interface FastEthernet0/4
interface FastEthernet0/5
switchport access vlan 10
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
switchport access vlan 20
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface Vlan1
no ip address
shutdown
interface Vlan10
mac-address 0005.5ec9.6201
ip address 192.168.10.5 255.255.255.0
interface Vlan20
mac-address 0005.5ec9.6202
ip address 192.168.20.5 255.255.255.0
interface Vlan30
mac-address 0005.5ec9.6203
ip address 192.168.30.5 255.255.255.0
interface Vlan40
mac-address 0005.5ec9.6204
ip address 192.168.40.5 255.255.255.0
ip default-gateway 192.168.1.1
line con 0
line vty 0 4
login
line vty 5 15
login
end
your Router1 has a default static route for network 192.168.10.0/24 pointing to the IP address of Vlan 40 on Switch0, that is why it doesn't work.
Remove the static route on Router1:
Router1(config)#no ip route 192.168.10.0 255.255.255.0
5 Replies 5
jakeparsons03
I don' think this attached when I first submitted it.
this looks like a Packet Tracer project. Post the .pkt file (zip it first before posting).
Sure! Here you go!
Thank you!
