OneX/TwinAx for VSS VSL on Sup-720
peter.robertson
I have attempted to create the VSS VSL between two Sup-720-10GB using OneX modules in the sups and passive TwinAx.   This fails.  Neither switch detects a peer and the VSL remains down.   I have also attempted using 10GB-SR optics in the OneX modules and the VSL still stays down.   If I use X2 optics instead of the OneX it works fine.
Does anyone know if the OneX modules are supported for VSS?   They work fine as uplinks from the 720s.   I have tested with 12.2(33)SXI12 and 15.1(2)SY1.
Thanks!
Bilal Nawaz
I haven't come across 'OneX' before but I do not think it is supported. List of supported modules for the SUP720-10GB are listed here:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps9336/product_data_sheet0900aecd806ed759_ps708_Products_Data_Sheet.html
X2-10GB-LR
10GBASE-LR X2 Module
X2-10GB-SR
10GBASE-SR X2 Module
X2-10GB-ER
10GBASE-ER X2 Module
X2-10GB-LX4
10GBASE-LX4 X2 Module
X2-10GB-CX4
10GBASE-CX4 X2 Module
Hope this helps.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Have you tried
service unsupported-transceiver
