OSFP redistribution into MBGP
pvandyk2005
I've noticed lately that OSPF redistribution into MBGP(multicast  address-family) is not working.
I'm using following topology with R1,R2 and R3 running one OSPF area 0 as IGP  with  125.1.X.R/24, and loopbacks 120.1.R.R/24
X = neighbor routers(R1,R2=12, R2,R3=23)
R = router number
Example: R1: 125.1.12.1, R2:125.1.12.2/125.1.23.2, R3:125.1.23.3
R1---R2---R3
  • R1's OSPF routing table is as follows
R1(config-router)#do show ip route ospf
     125.0.0.0/24 is subnetted, 3  subnets
O       125.1.23.0 [110/20] via 125.1.12.2, 00:44:34,  FastEthernet0/1
     120.0.0.0/8 is variably subnetted, 3 subnets, 2  masks
O       120.1.3.3/32 [110/21] via 125.1.12.2, 00:44:34,  FastEthernet0/1
O       120.1.2.2/32 [110/11] via 125.1.12.2, 00:39:37,  FastEthernet0/1
  • I'm running BGP as 123 on all routers with R2 as RouteReflector and I'm also  activating multicast ipv4 address family
R1(config-router)#do show bgp ipv4 multicast summary
BGP router identifier  120.1.1.1, local AS number 123
Neighbor        V    AS MsgRcvd MsgSent    TblVer  InQ OutQ Up/Down  State/PfxRcd
120.1.2.2       4   123      57       57        1    0    0 00:36:56        0
R2(config-router-af)#do show bgp ipv4 multicast summary
BGP router  identifier 120.1.2.2, local AS number 123
120.1.1.1       4   123       58      58        1    0    0 00:37:24        0
120.1.3.3       4   123       53      53        1    0    0 00:37:59        0
R3(config-router-af)#do show bgp ipv4 multicast summary
BGP router  identifier 120.1.3.3, local AS number 123
120.1.2.2       4   123       17      17        1    0    0 00:01:38        0
  • At this moment, everything should be ready for redistribution
R1:
router bgp 123
address-family ipv4 multicast
redistribute ospf 1 match internal
! However, nothing is injected into BGP
R1(config-router)#
  • I enable "ip multicast-routing" on all routers in the  network, I'm also enabling PIM SM on all interfaces. The result is the same, no  prefixes were injected into MBGP
Is there anybody who had this  problem before?
daniel.dib
Level 7
Level 7
I remember running into this while preparing for the CCIE.
Try to put a route-map under multicast address family that sets the next-hop. Something simple like
route-map SET_NH permit 10
set ip next-hop x.x.x.x
router bgp 123
redistribute ospf 1 match internal route-map SET_NH
I never found a good reason for why it behaves like this but try it out to see if it works.
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
Please rate helpful posts.
