OSPF-4-NOVALIDKEY
mabeita
I have a cisco router   isr4300 running
Cisco IOS XE Software, Version 03.13.02.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.4(3)S2, RELEASE SOFTWARE (fc3)
getting this error on all interface
May 14 12:03:42.770 MDT: %OSPF-4-NOVALIDKEY: No valid authentication send key is available on interface GigabitEthernet0/0/0.35
May 14 12:04:42.770 MDT: %OSPF-4-NOVALIDKEY: No valid authentication send key is available on interface GigabitEthernet0/0/0.60
May 14 12:05:43.872 MDT: %OSPF-4-NOVALIDKEY: No valid authentication send key is available on interface GigabitEthernet0/0/0.100
May 14 12:06:44.119 MDT: %OSPF-4-NOVALIDKEY: No valid authentication send key is available on interface GigabitEthernet0/0/0.35
May 14 12:07:44.411 MDT: %OSPF-4-NOVALIDKEY: No valid authentication send key is available on interface GigabitEthernet0/0/0.55
May 14 12:08:45.715 MDT: %OSPF-4-NOVALIDKEY: No valid authentication send key is available on interface GigabitEthernet0/0/0.100
May 14 12:09:46.386 MDT: %OSPF-4-NOVALIDKEY: No valid authentication send key is available on interface GigabitEthernet0/0/0.180
have double check my config can't seem to fine anything
Rolf Fischer
Level 9
Level 9
Please have a look at this discussion and see if it helps solving your problem as well:
https://supportforums.cisco.com/discussion/12428001/asr900-ospf-4-novalidkey-no-valid-authentication-send-key-available-interface
Otherwise a 'debug ip ospf adj' should provide useful information. If you have many non-passive OSPF interfaces, you should limit the output with 'debug condition <ospf-interface>' first.
Rolf
Rolf Fischer
Level 9
Level 9
Rolf
