hi all,
i would like an advice on OSPF design.
i have got to implement OSPF within our network and i am not really sure what design to go for.
OSPF will be running between two 7206 edge routers, two 4506 switches and two nokia firewall.
i was wondering if the best solution is to create only a single area for this design, or an hierarchical design is always preferred even in small network.
See attached for some details
thank you for your support.
