Ospf checksum error
parthiban chinnaya
Community Member
                   I am seeing the following error in Nexus 7000.
%OSPF-4-CKSM_ERR:  ospf-2 [3482] (default) Bad OSPF checksum in packet ffff computed 0 from 10.20.100.2 on Ethernet1/6
%OSPF-4-CKSM_ERR:  ospf-2 [3482] (default) Bad OSPF checksum in packet ffff computed 0 from 10.20.0.10 on Ethernet1/5
The far end switch is a third party vendor.
what does this error mean.
Bilal Nawaz
Error Message OSPF-4-CKSM_ERR Format: Bad OSPF checksum in packet %hx computed %hx
from %s on %s
Explanation A OSPF packet with invalid checksum was received
Parameters: Checksum value, Checksum value, Source IP address, Interface name
http://www.cisco.com/en/US/docs/switches/datacenter/sw/system_messages/reference/sl_7Krouting.html#wp1354080
Hope this helps
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
InayathUlla Sharieff
Hi Parthiban,
from %s on %s
Parameters: Checksum value, Checksum value, Source IP address, Interface name ...
Recommended Action    No action is required.
The %OSPF-4- CKSM_ERR: error message indicates that an Open Shortest Path
First (OSPF) router has received an invalid OSPF packet. The cause of the
error is included in the error message itself.
*       A device between the neighbors, such as a switch, is corrupting
the packet.
*       The sending router's packet is invalid. In this case, either the
sending router's interface is bad, or the error is caused by a software
bug.
*       The receiving router is calculating the wrong checksum. In this
case, either the receiving router's interface is bad, or the error is
caused
by a software bug. This is the least likely cause of this error message.
Inayath
*Plz rate all usefull posts.
