OSPF cost calculation
zaidiatifs
hi people , i need to undertand how OSPF calculates the cost as its metric, i know the the formula to calculate is  100000000/interface bandwidth, but how can we convert the interface bandwidth which is in KBIT to BPS ?
please let me know the detailed procedure to accomplish this .
also for the serial Links i have noticed that the interface bandwidth is 1544 kbit or 128 kbit , also for the fast ethernet or ethernet interfaces the badwidth seems to be 100000 kbit
please specify the calculation of cost for these values
kindly let me know that ,
also kindly suggest me a Topology ( OSPF network diagram ) where i can get to see DR and BDR's as i believe it only happens on broadcast and NBMA
7 Replies 7
Edison Ortiz
Default is 100Mbps/Interface Bandwidth
56-kbps serial link—Default cost is 1785
•64-kbps serial link—Default cost is 1562
•T1 (1.544-Mbps serial link)—Default cost is 64
•E1 (2.048-Mbps serial link)—Default cost is 48
•4-Mbps Token Ring—Default cost is 25
•Ethernet—Default cost is 10
•FastEthernet—Default cost is 1
•16-Mbps Token Ring—Default cost is 6
•FDDI—Default cost is 1
•X25—Default cost is 5208
•Asynchronous—Default cost is 10,000
•ATM— Default cost is 1
You can use DR and BDR on any link topology if desired, simply change the ospf network type under the interface.
i already know that ..what i need to know is how these are calculated using the formula
Hi Atif,
First of all to let u know your query is not clear and next to it there is no term KBIT in Cisco.
please have a look and let me know
So, 100Mbps/1.544Mbps = ?
If you have a 128Kbps connection, 100Mbps/.128Mbps =?
That's why I provided the table. A quick math will given you the answer.
Not sure exactly what your question is but:
8=Bits=1 Byte
1024 Byte=1 Kilobyte
1024 Kilobyte=1 Megabyte
So, in your case, the interface is 1544 Kilobyte which is equal to about 1.5 Megabyte.
and the OSPF cost is 64. as Edison already answerd that.
Although the question has already been answered perfectly, I'd like to add two details:
  1. The standards do not define the way how the cost is calculated; the formula above referes to the (wise) Cisco implemetation. I've heard that some vendors set the default costs of any interface to 1 (Hopcount, like RIP).
  2. 100 Mbps is the default value for the numerator. That's why I prefer the formula "reference-bandwidth/link-speed"
Rolf
