ospf equal cost paths
jonk34567
Level 4
Level 4
what is the maximum number of equal cost paths that can be placed on a ospf router ? also what is the default value ?
Yes, But most of the cases the default value is 4 in Cisco routers. You can find some changes in SMB routers, which also depend on router model numbers.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Deepak Kumar
ospf Default value = 4
ospf max equal cost paths = 6
Deepak Kumar
Deepak Kumar,
but does it depend on cisco os version and platform ?
Deepak Kumar
Deepak Kumar,
thanks you very much
