OSPF Error
dal
Level 7
Level 7
Hi!
I have 2 OSPF Areas set up, and it works fine, but one of the 3550's is producing an error:
013476: *Mar 2 13:08:46: %OSPF-4-ERRRCV: Received invalid packet: mismatch area ID, from backbone area must be virtual-link but not found from 10.50.55.1, Vlan1
I have ran that error through the Output interpreter, and I have also tried to follow this guide:
http://www.cisco.com/en/US/customer/tech/tk365/technologies_tech_note09186a0080094819.shtml#probone
But no luck fixing it.
This is OSPF is configured on my 2 switches:
Switch#1:
router ospf 1
router-id 10.50.55.1
log-adjacency-changes
no capability lls
area 0 range 10.0.0.0 255.0.0.0
area 1.1.1.1 range 172.16.0.0 255.254.0.0
network 10.0.0.0 0.255.255.255 area 0
network 172.16.0.0 0.1.255.255 area 1.1.1.1
default-information originate
Switch#2: (This is the one producing error)
router ospf 1
router-id 172.16.0.1
Can anyone see something wrong that I don't see myself?
Thanks.
It appears that switch#2 receives the hello messages issued by switch#1 for area 0. This is probably due to the broadcast domain being shared for the interfaces in area 0 and area 1 on switch#1.
Hope this helps,
