OSPF not up between 4510E and ASA 5540-(8.4)
searskarthik
between 4510 E(172.29.95.2) and ASA(inside IP 172.29.95.19) ospf not up, but between L3 interface tenGig 6/1 OSPF running with area0
here is config of switch.
interface TenGigabitEthernet6/1
  no switchport
ip address 172.29.64.62 255.255.255.252
interface Vlan110
description management
ip address 172.29.95.2 255.255.255.224
standby 110 ip 172.29.95.1
standby 110 priority 110
standby 110 preempt
standby 110 authentication VLAN110
standby 110 name management
router ospf 65482
router-id 172.29.95.2
log-adjacency-changes
summary-address 172.29.80.0 255.255.240.0
network 172.29.64.0 0.0.0.31 area 0
network 172.29.64.32 0.0.0.7 area 0
network 172.29.64.60 0.0.0.3 area 0
ASA config for OSPF:
router ospf 65482
router-id 172.29.95.19
network 172.29.64.60 255.255.255.252 area 0
network 172.29.64.0 255.255.240.0 area 0
network 172.29.80.0 255.255.240.0 area 0
area 0
log-adj-changes detail
default-information originate metric 1 metric-type 1
could you please help on this.
thanks
MK
2 Accepted Solutions
Reza Sharifi
In your config you have not added 172.29.95.2 255.255.255.224 to the OSPF process.  Add this to the switch and the firewall OSPF and try again.
Hi there,
You need to advertise the vlan110 networks on both the ospf processes otherwise they can't exchange lsa and other ospf info.
Hope this helps
Alessio
Ps: pay attention to the summary you are doing..
Reza Sharifi
Hi there,
Hope this helps
Alessio
searskarthik
thanks to both you,
Now OSPF is up,
ASA:
router ospf 65482
network 172.29.95.19 255.255.255.255 area 0
area 0
Switch:
router ospf 65482
network 172.29.95.0 0.0.0.31 area 0
