OSPF problem: Neighbor Down 1-2 times per day
Leo Liu
We have 4 devices are running OSPF (3 cisco routers and 1 Juniper firewall as show in attachment file). In last few months, we got Neighbot Down message almost 1-2 times per day. Network between them interrupt for a short time and even monitoring mechanism does not aware the interruption(down time is too short). Could I have your advice of any possible root cause to this problem?
Timer intervals configured to all devices are same: Hello 10, Dead 40, Wait 40, Retransmit 5
Neighbor A
Neighbor A#sh ip ospf neighbor
Neighbor ID     Pri   State           Dead Time   Address         Interface
172.16.255.128    1   FULL/DROTHER    00:00:34    172.16.108.11   GigabitEthernet0/11
172.16.255.130    1   FULL/DR         00:00:33    172.16.108.2    GigabitEthernet0/11
172.16.255.64     1   FULL/DROTHER    00:00:34    172.16.107.1    GigabitEthernet0/12
172.16.255.128    1   FULL/DROTHER    00:00:38    172.16.107.11   GigabitEthernet0/12
172.16.255.130    1   FULL/DR         00:00:38    172.16.107.7    GigabitEthernet0/12
Neighbor A#show log
Mar 16 06:03:33.159: %OSPF-5-ADJCHG: Process 1, Nbr 172.16.255.128 on GigabitEthernet0/12 from FULL to DOWN, Neighbor Down: Dead timer expired
Mar 16 06:03:50.137: %OSPF-5-ADJCHG: Process 1, Nbr 172.16.255.128 on GigabitEthernet0/12 from LOADING to FULL, Loading Done
Mar 16 21:15:05.509: %OSPF-5-ADJCHG: Process 1, Nbr 172.16.255.64 on GigabitEthernet0/12 from LOADING to FULL, Loading Done
Neighbor B
Neighbor B#sh ip ospf neighbor
172.16.255.128    1   FULL/DROTHER    00:00:36    172.16.108.11   GigabitEthernet0/11
172.16.255.129    1   FULL/BDR        00:00:35    172.16.108.1    GigabitEthernet0/11
172.16.255.64     1   FULL/DROTHER    00:00:39    172.16.107.1    GigabitEthernet0/12
172.16.255.128    1   FULL/DROTHER    00:00:30    172.16.107.11   GigabitEthernet0/12
172.16.255.129    1   FULL/BDR        00:00:35    172.16.107.6    GigabitEthernet0/12
Neighbor B#show log
Mar 16 06:03:33.143: %OSPF-5-ADJCHG: Process 1, Nbr 172.16.255.128 on GigabitEthernet0/12 from FULL to DOWN, Neighbor Down: Dead timer expired
Mar 16 06:03:50.122: %OSPF-5-ADJCHG: Process 1, Nbr 172.16.255.128 on GigabitEthernet0/12 from LOADING to FULL, Loading Done
Mar 16 21:14:58.054: %OSPF-5-ADJCHG: Process 1, Nbr 172.16.255.64 on GigabitEthernet0/12 from LOADING to FULL, Loading Done
Mar 16 21:15:03.800: %OSPF-5-ADJCHG: Process 1, Nbr 172.16.255.128 on GigabitEthernet0/12 from LOADING to FULL, Loading Done
Neighbor C
Neighbor C#sh ip ospf neighbor
172.16.255.129    1   FULL/BDR        00:00:35    172.16.108.1    FastEthernet0/1/0
172.16.255.130    1   FULL/DR         00:00:38    172.16.108.2    FastEthernet0/1/0
172.16.255.64     1   2WAY/DROTHER    00:00:30    172.16.107.1    FastEthernet0/0/1
172.16.255.129    1   FULL/BDR        00:00:35    172.16.107.6    FastEthernet0/0/1
172.16.255.130    1   FULL/DR         00:00:33    172.16.107.7    FastEthernet0/0/1
Neighbor C#show log
Mar 16 06:03:23.571: %OSPF-5-ADJCHG: Process 1, Nbr 172.16.255.130 on FastEthernet0/0/1 from FULL to DOWN, Neighbor Down: Dead timer expired
Mar 16 06:03:25.479: %OSPF-5-ADJCHG: Process 1, Nbr 172.16.255.129 on FastEthernet0/0/1 from FULL to DOWN, Neighbor Down: Dead timer expired
Mar 16 06:03:29.415: %OSPF-5-ADJCHG: Process 1, Nbr 172.16.255.64 on FastEthernet0/0/1 from EXSTART to DOWN, Neighbor Down: Dead timer expired
Mar 16 06:03:50.112: %OSPF-5-ADJCHG: Process 1, Nbr 172.16.255.129 on FastEthernet0/0/1 from LOADING to FULL, Loading Done
Mar 16 06:03:50.112: %OSPF-5-ADJCHG: Process 1, Nbr 172.16.255.130 on FastEthernet0/0/1 from LOADING to FULL, Loading Done
Mar 16 21:14:53.740: %OSPF-5-ADJCHG: Process 1, Nbr 172.16.255.130 on FastEthernet0/0/1 from FULL to DOWN, Neighbor Down: Dead timer expired
Mar 16 21:15:03.793: %OSPF-5-ADJCHG: Process 1, Nbr 172.16.255.130 on FastEthernet0/0/1 from LOADING to FULL, Loading Done
9 Replies 9
LA-Engineer
How's the cpu utilization on these routers during the flap?
We were not monitor CPU utilization of these routers and I just put them in monitoring. The flap often happens in one minute and I am not sure if it will be monitored. I will provide monitor results after next flap.
How did u configure the switch between Router C and Firewall D, since you are forming  all the neighbors on F0/0/1 which is between Router C and Firewall
On the switch between C and D, 3 ports (to C, to D and to A,B switch) were assigned with same vlan.
Following interfaces are all configured in subnet 172.16.107.0/24:
  • G0/12 on Router A
  • G0/12 on Router B
  • F0/0/1 on router C
  • Outside (to switch) on Firewall D
We have interupt this morning and CPU utilization of these routers are quite low.
CPU utilization:
Router A: 5%             Router B: 5%        Router C: 2%
show log:
Router A
Mar 20 01:40:17.252: %OSPF-5-ADJCHG: Process 1, Nbr 172.16.255.128 on GigabitEthernet0/12 from LOADING to FULL, Loading Done
Mar 20 01:40:26.203: %OSPF-5-ADJCHG: Process 1, Nbr 172.16.255.64 on GigabitEthernet0/12 from LOADING to FULL, Loading Done
Router B
Mar 20 01:40:24.597: %OSPF-5-ADJCHG: Process 1, Nbr 172.16.255.128 on GigabitEthernet0/12 from LOADING to FULL, Loading Done
Router C
Mar 20 01:40:16.163: %OSPF-5-ADJCHG: Process 1, Nbr 172.16.255.129 on FastEthernet0/0/1 from FULL to DOWN, Neighbor Down: Dead timer expired
Mar 20 01:40:16.179: %OSPF-5-ADJCHG: Process 1, Nbr 172.16.255.64 on FastEthernet0/0/1 from LOADING to FULL, Loading Done
Mar 20 01:40:17.243: %OSPF-5-ADJCHG: Process 1, Nbr 172.16.255.129 on FastEthernet0/0/1 from LOADING to FULL, Loading Done
Mar 20 01:40:24.559: %OSPF-5-ADJCHG: Process 1, Nbr 172.16.255.130 on FastEthernet0/0/1 from FULL to DOWN, Neighbor Down: Dead timer expired
Mar 20 01:40:24.591: %OSPF-5-ADJCHG: Process 1, Nbr 172.16.255.130 on FastEthernet0/0/1 from LOADING to FULL, Loading Done
I am thinking to replace a switch between C and D, any advice? Thanks.
rkbala3560
is there any L2 loops happening in network..
I think no L2 loops in the network. We have spanning tree configured on switches connecting to router A & B.
VLAN0108
  Spanning tree enabled protocol ieee
  Root ID    Priority    32876
             Address     5c50.15a3.8480
             This bridge is the root
             Hello Time   2 sec  Max Age 20 sec  Forward Delay 15 sec
  Bridge ID  Priority    32876  (priority 32768 sys-id-ext 108)
             Aging Time  300 sec
Interface           Role Sts Cost      Prio.Nbr Type
Gi1/0/45            Desg FWD 4         128.45   P2p Edge
Gi1/0/47            Desg FWD 19        128.47   P2p Edge
Gi1/0/48            Desg FWD 4         128.48   P2p Edge
VLAN0107
  Root ID    Priority    32875
             Address     5c50.15ec.f000
  Bridge ID  Priority    32875  (priority 32768 sys-id-ext 107)
             Aging Time  300 sec
LA-Engineer
It looks like the adjacency on multiple interfaces are flapping.  Are all these routers connected through a common switch?
Please refer to topology as attach file I just updated. Actually we have 3 offices (site 1, 2 and 3) are connecting with 10M FTTB link between 2 sites.
