OSPF route not installed in routing table
DOUGMALLOCH1
Hi guys,
I have got the following setup:
> 3-legged ASA setup (external, DMZ, internal)
> External interface uses 100.100.100.0/30 (substitute for real addresses)
> DMZ interface uses 10.185.3.0/24 (public addresses are served with NAT at external interface)
> Internal interface uses 10.185.100.20/30 (a P2P link to a Layer 3 switch)
> ASA end is 10.185.100.21, Switch end is 10.185.100.22
> Both ASA and Switch are running OSPF
> ASA is redistributing connected interfaces (for the purpose of this case, the aforementioned DMZ private subnet)
> OSPF neighbourship is good (with standard OSPF settings - area 0, network type, hello/dead timers, etc)
> IP routing on switch is enabled
The question is why does the DMZ 10.185.3.0/24 subnet not appear on the Switch routing table?
> That specific route is present in the OSPF database on the Switch (see below)
> It is a Type 5 LSA due to the aforementioned redistribution at ASA
> No other more-specific routes in this scenario
> show ip route 10.185.3.0 says subnet is not in routing table
> Notice no Routing bit set on this LSA line below too
> I have read Cisco's common OSPF routing problems in regards to this topic
Many thanks.
  LS age: 2828
  Options: (No TOS-capability, DC)
  LS Type: AS External Link
  Link State ID: 100.100.100.0 (External Network Number )
  Advertising Router: 10.185.100.21
  LS Seq Number: 800000D4
  Checksum: 0x84DA
  Length: 36
  Network Mask: /30
        Metric Type: 1 (Comparable directly to link state metric)
        TOS: 0
        Metric: 1
        Forward Address: 0.0.0.0
        External Route Tag: 0
Reza Sharifi
Is Inter interface communication enabled on the firewall?
same-security-traffic permit inter-interface
Hello.
Have you checked LSA 10.185.3.0 on the switch? Do you have it in LSDB? Could you provide it?
Do you see ASA as ASBR (sh ip ospf border)?
