ospf routes summarization at abr
sarahr202
Level 5
Level 5
Hi every body.
It has been a long while since  I came to this forum last time.
1) Here is my setup:
R1-area 0-----R2---area 1-----R3
R1 has loopback addresses:   10.1.1.1/24   10.1.2.2/24 ( these loopback addresses are configured with network type  point to point)
R2 is ABR.
The goal is the summarize 10.1.1.0/24 10.1.2.0/24 as 10.0.0.0/8  and inject it into area 1 at ABR.
R2 configuration is shown below:
router ospf 1
router-id 2.2.2.2
log-adjacency-changes
area 1 range 10.0.0.0 255.0.0.0
network 199.199.199.2 0.0.0.0 area 0
network 200.200.200.2 0.0.0.0 area 1
Routing table at R2 is shown below:
C    200.200.200.0/24 is directly connected, Serial0/1
C    199.199.199.0/24 is directly connected, Serial0/0
     10.0.0.0/24 is subnetted, 2 subnets
O       10.1.2.0 [110/65] via 199.199.199.1, 00:10:29, Serial0/0
O       10.1.1.0 [110/65] via 199.199.199.1, 00:10:29, Serial0/0
The problem is  R2 is not summarizing the following routes as 10.0.0.0/8 and injecting it into area 1 even though" area1 range 10.0.0.0 255.0.0.0 " is configured.
O   10.1.2.2
O    10.1.1.0
2)   My second question  is can we summarize external routes at abr?   for example   if R2 is abr and has following routes,  can we perform summarization at  abr?  I understand  Such summarization should be done at asbr but iam just curious.
OE2   199.199.198.0/255
O E2  199.199.199.0/255
Thanks and have a great  week.
3 Accepted Solutions
Reza Sharifi
Sara
summarize to area 0 not 1
Sarah,
Sorry, I did not see your second post.
glad you figured it out
Richard Burts
Question 1 - yes glad that you figured it out.
Question 2 - no you can not summarize external at ABR, only at ASBR.
Rick
Rick
sarahr202
Level 5
Level 5
I found the answer for the first question.
area x range  10.0.0.0 255.0.0.0
area x refers to the area where subnets exist.  In my set up, I erroneously configured area 1 rather than area 0.
thanks and have a great week
Sarah,
Reza Sharifi
Sara
Richard Burts
Rick
Rick
