OTV concept
abi01online
                   Can you somebody please explain OTV concept in Nexus 7K
5 Replies 5
thank you for reply..
Marvin Rhoads
There is also a very nice podcast that was done by the guys at Packetpushers (and sponsored by Cisco) just recently.
     http://packetpushers.net/show-155-integrating-otv-fabricpath-lisp-sponsored/
Also refer to Priority Queue shows #24 and #25 at the same site for some deep dive material.
Hello:
The OTV is what will give you the possibility to extend the Red Lan between two points in geographically separate areas.
The concept is that the OTV encapsulates the Layer 2 over Layer 3, with the proviso that there is equipment at the ends forming the OTV tunnel, for this you need to implemented the concept of Jumbo Frames. and Rapid STP.
jkilleda
Level 3
Level 3
OTV concept
It is a technology which is used to extend existing L2 infrastructure over L3 network .
