Highlighted
Beginner
our stack power is ok, why do it report logs frequently?
------------------ show stack-power ------------------ Power stack name: Powerstack-1 Stack mode: Redundant strict Stack topology: Ring Switch 1: Power budget: 223 Low port priority value: 20 High port priority value: 12 Switch priority value: 5 Port 1 status: Connected Port 2 status: Connected Neighbor on port 1: ccef.4852.ba00 Neighbor on port 2: ccef.4852.ba00 Switch 2: Power budget: 223 Low port priority value: 22 High port priority value: 13 Switch priority value: 4 Port 1 status: Connected Port 2 status: Connected Neighbor on port 1: ccef.4851.dd80 Neighbor on port 2: ccef.4851.dd80 -------------- show env all ------------------ FAN 1 is OK FAN 2 is OK FAN PS-1 is OK FAN PS-2 is OK SYSTEM TEMPERATURE is OK System Temperature Value: 24 Degree Celsius System Temperature State: GREEN Yellow Threshold : 46 Degree Celsius Red Threshold : 60 Degree Celsius SW PID Serial# Status Sys Pwr PoE Pwr Watts --- ------------------ ---------- --------------- ------- ------- ----- 1A C3KX-PWR-350WAC LIT1534024J OK Good Good 350/0 1B C3KX-PWR-350WAC DTN1530L0C7 OK Good Good 350/0 2A C3KX-PWR-350WAC DTN1530L005 OK Good Good 350/0 2B C3KX-PWR-350WAC DTN1530L0L6 OK Good Good 350/0 SW Status RPS Name RPS Serial# RPS Port# -- ------------- ---------------- ----------- --------- 1 Not Present <> 2 Not Present <> 036390: Mar 27 01:43:02: %PLATFORM_STACKPOWER-4-REDUNDANCY_LOSS: Switch 2's power stack lost redundancy and is now operating in power sharing mode 036391: Mar 27 01:44:02: %PLATFORM_STACKPOWER-4-REDUNDANCY_LOSS: Switch 2's power stack lost redundancy and is now operating in power sharing mode 036392: Mar 27 01:45:02: %PLATFORM_STACKPOWER-4-REDUNDANCY_LOSS: Switch 2's power stack lost redundancy and is now operating in power sharing mode 036393: Mar 27 01:46:02: %PLATFORM_STACKPOWER-4-REDUNDANCY_LOSS: Switch 2's power stack lost redundancy and is now operating in power sharing mode 036394: Mar 27 01:47:02: %PLATFORM_STACKPOWER-4-REDUNDANCY_LOSS: Switch 2's power stack lost redundancy and is now operating in power sharing mode 036395: Mar 27 01:48:02: %PLATFORM_STACKPOWER-4-REDUNDANCY_LOSS: Switch 2's power stack lost redundancy and is now operating in power sharing mode 036396: Mar 27 01:49:02: %PLATFORM_STACKPOWER-4-REDUNDANCY_LOSS: Switch 2's power stack lost redundancy and is now operating in power sharing mode 036397: Mar 27 01:50:03: %PLATFORM_STACKPOWER-4-REDUNDANCY_LOSS: Switch 2's power stack lost redundancy and is now operating in power sharing mode 036398: Mar 27 01:51:03: %PLATFORM_STACKPOWER-4-REDUNDANCY_LOSS: Switch 2's power stack lost redundancy and is now operating in power sharing mode 036399: Mar 27 01:52:03: %PLATFORM_STACKPOWER-4-REDUNDANCY_LOSS: Switch 2's power stack lost redundancy and is now operating in power sharing mode 036400: Mar 27 01:53:03: %PLATFORM_STACKPOWER-4-REDUNDANCY_LOSS: Switch 2's power stack lost redundancy and is now operating in power sharing mode 036401: Mar 27 01:54:03: %PLATFORM_STACKPOWER-4-REDUNDANCY_LOSS: Switch 2's power stack lost redundancy and is now operating in power sharing mode 036402: Mar 27 01:55:03: %PLATFORM_STACKPOWER-4-REDUNDANCY_LOSS: Switch 2's power stack lost redundancy and is now operating in power sharing mode
1 REPLY 1
Highlighted
VIP Advocate
As you said that all hardware side you had verified that everything is working fine. What is the hardware model and software version?
We noticed the same issue was reported due to a bug and multiple models were affected.
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCtu37997/?rfs=iqvred
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvi89146/?rfs=iqvred
Workaround:
Re-seating the stack-power cables has been observed to clear this issue in some cases.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution If this comment will make help you!
Content for Community-Ad
